Platform designer testbench PLL component does not match entity
I am using Quartus 18.0 and generating testbench from the Platform designer (aks Qsys) system.
The Qsys system contains a PLL. When I generate testbench files, the list contains a .vho and a .vo file. One contains the PLL entity (VHDL) while the other contains the PLL module (Verilog). The input signals in both these files have no default values. Qsys usually likes to assign default values to input ports in RTL code.
The problem is that when I try to compile the simulation files, it fails. The source of the problem is how the component declaration and portmap has been done between the synthesis and simulation top level .vhd file.
The synthesis file component declaration in top level file is:
component S_PLL is
port (
clk : in std_logic := 'X'; -- clk
reset : in std_logic := 'X'; -- reset
read : in std_logic := 'X'; -- read
write : in std_logic := 'X'; -- write
address : in std_logic_vector(1 downto 0) := (others => 'X'); -- address
readdata : out std_logic_vector(31 downto 0); -- readdata
writedata : in std_logic_vector(31 downto 0) := (others => 'X'); -- writedata
c0 : out std_logic; -- clk
c2 : out std_logic; -- clk
scandone : out std_logic; -- export
scandataout : out std_logic; -- export
c1 : out std_logic; -- clk
c3 : out std_logic; -- clk
c4 : out std_logic; -- clk
areset : in std_logic := 'X'; -- export
locked : out std_logic; -- export
phasedone : out std_logic; -- export
phasecounterselect : in std_logic_vector(2 downto 0) := (others => 'X'); -- export
phaseupdown : in std_logic := 'X'; -- export
phasestep : in std_logic := 'X'; -- export
scanclk : in std_logic := 'X'; -- export
scanclkena : in std_logic := 'X'; -- export
scandata : in std_logic := 'X'; -- export
configupdate : in std_logic := 'X' -- export
end component S_PLL;This changes in the simulation top level file to:
component S_PLL is
port (
c2 : out std_logic -- clk
end component S_PLL;Why are they different? Compiling simulation files fails because the component is missing many ports.
- Vicky1
here we can clearly see that few ports are missing.
Could you provide your project file?(Project Menu-> Archive Project) for replication?
Vicky
- Vicky1
Could you please share the instantiation template for verilog from path as below,
Generate Menu->Instantiation template
Also check by editing those signal mention as 'export', name them & try to check testbench under *_tb directory for testbench directory.
Vicky
- Vicky1
Have you resolved the issue?
Should I consider that case to be closed?
Vicky
- gyuunyuu
Contributor
If we change the synthesis files to Verilog, the same issue is observed:
Synthesis top level:
SPRINT_OSI_S_PLL pll ( .clk (clk_33m_clk), // inclk_interface.clk .reset (rst_controller_reset_out_reset), // inclk_interface_reset.reset .read (mm_interconnect_0_pll_pll_slave_read), // pll_slave.read .write (mm_interconnect_0_pll_pll_slave_write), // .write .address (mm_interconnect_0_pll_pll_slave_address), // .address .readdata (mm_interconnect_0_pll_pll_slave_readdata), // .readdata .writedata (mm_interconnect_0_pll_pll_slave_writedata), // .writedata .c0 (pll_c0_clk), // c0.clk .c2 (pll_c2_clk), // c2.clk .scandone (), // (terminated) .scandataout (), // (terminated) .c1 (), // (terminated) .c3 (), // (terminated) .c4 (), // (terminated) .areset (1'b0), // (terminated) .locked (), // (terminated) .phasedone (), // (terminated) .phasecounterselect (3'b000), // (terminated) .phaseupdown (1'b0), // (terminated) .phasestep (1'b0), // (terminated) .scanclk (1'b0), // (terminated) .scanclkena (1'b0), // (terminated) .scandata (1'b0), // (terminated) .configupdate (1'b0) // (terminated) );Simulation top level
SPRINT_OSI_S_PLL pll ( .clk (clk_33m_clk), // inclk_interface.clk .reset (rst_controller_reset_out_reset), // inclk_interface_reset.reset .read (mm_interconnect_0_pll_pll_slave_read), // pll_slave.read .write (mm_interconnect_0_pll_pll_slave_write), // .write .address (mm_interconnect_0_pll_pll_slave_address), // .address .readdata (mm_interconnect_0_pll_pll_slave_readdata), // .readdata .writedata (mm_interconnect_0_pll_pll_slave_writedata), // .writedata .c0 (pll_c0_clk), // c0.clk .c2 (pll_c2_clk) // c2.clk ); - gyuunyuu
Contributor
This is clearly a bug in Qsys. The only method to solve this at present would be to force the Qsys to make these ports visible.
I had a similar problem before where no VHDL files were being generated at all. I uninstalled and reinstalled Quartus and the problem went away.
If you can't see this problem on your end then this case should be closed as it is.
