gyuunyuu
Contributor
7 years agoPlatform designer testbench PLL component does not match entity
I am using Quartus 18.0 and generating testbench from the Platform designer (aks Qsys) system. The Qsys system contains a PLL. When I generate testbench files, the list contains a .vho and a .vo fi...
gyuunyuu
Contributor
7 years agoThis is clearly a bug in Qsys. The only method to solve this at present would be to force the Qsys to make these ports visible.
I had a similar problem before where no VHDL files were being generated at all. I uninstalled and reinstalled Quartus and the problem went away.
If you can't see this problem on your end then this case should be closed as it is.
