gyuunyuu
Contributor
7 years agoPlatform designer testbench PLL component does not match entity
I am using Quartus 18.0 and generating testbench from the Platform designer (aks Qsys) system. The Qsys system contains a PLL. When I generate testbench files, the list contains a .vho and a .vo fi...
Vicky1
7 years agoHi,
Could you please share the instantiation template for verilog from path as below,
Generate Menu->Instantiation template
Also check by editing those signal mention as 'export', name them & try to check testbench under *_tb directory for testbench directory.
Vicky
