Platform Designer Nios HDL generation
- 3 years ago
If you look into the project directory -> ip -> {example_ip_name} -> synth folder, that's where the top level vhdl file generated for that particular IP, used in your qsys system.
example file path: .../<project directory>/ip/<example_ip_name>/synth
You can find it at the top level qsys synth folder as well, go to project directory -> {top_qsys_name} -> synth.
example file path: .../<project directory>/<top_qsys>/synth
The other generated file with sub-system component are usually generated in .v or .sv files format.
example file path with sub-system/ip:
.../<project directory>/ip/<example_ip_name>/<sub-system>/synth
.../<project directory>/<top_qsys>/<example_ip_name>/synth
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
Thank you for acknowledging the solution provided. I'm glad to hear that your question has been addressed.
Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Richard Tan
