Subhabrata's avatar
Subhabrata
3 years ago
Platform Designer Nios HDL generation
I have created NIOS II based system in Platform Designer (Quartus Prime Lite 18.1). completed all connection, memory mapping and IRQ. But to generate HDL (Generate -> generate HDL), I am getting on...
  • RichardT_altera's avatar
    3 years ago
    If you look into the project directory -> ip -> {example_ip_name} -> synth folder, that's where the top level vhdl file generated for that particular IP, used in your qsys system.
    example file path: .../<project directory>/ip/<example_ip_name>/synth
    You can find it at the top level qsys synth folder as well, go to project directory -> {top_qsys_name} -> synth.
    example file path: .../<project directory>/<top_qsys>/synth
    The other generated file with sub-system component are usually generated in .v or .sv files format.
    example file path with sub-system/ip:
    .../<project directory>/ip/<example_ip_name>/<sub-system>/synth
    .../<project directory>/<top_qsys>/<example_ip_name>/synth
    Richard Tan
    p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
