Steve-Mowbray-ENL
3 years agoPlatform Designer Instance Parameters script update a library component parameter
Hi Attempting to make use of instance parameters to synchronise all dependencies in a subsystem -- basically component editor generated custom component parameters works great but I am finding it t...
- 3 years ago
I think you have to look in the Details or Documentation button to get the actual name of the parameter, not the human readable name that appears in the parameter editor like what you are using here. The tooltip when hovering over the parameter might provide this as well.
sstrell
3 years agoI think you have to look in the Details or Documentation button to get the actual name of the parameter, not the human readable name that appears in the parameter editor like what you are using here. The tooltip when hovering over the parameter might provide this as well.
Steve-Mowbray-ENL
3 years agoThanks sstrell
Details or documentation button doesn't give any clues at least for the Clock Bridge library component but the tooltip does the trick:
Sorted now with your help
Steve
