Platform Designer- SDRAM
- 3 years ago
Hi Tim,
For the SDRAM Controller Intel FPGA IP, the controller can support standard SDRAM as described in PC100 specification by JEDEC.
Basically the spec for clock frequency in running at 100MHz.
You may visit the link below for reference of SDRAM Controller Core.
https://www.intel.com/content/www/us/en/docs/programmable/683130/23-1/core-overview-29412.html
Adzim
I presume you mean Platform Designer. And of course you have to specify clock frequency. It's right on the General tab in the parameter editor. Are you referring to something different?
- TimSch3 years ago
Thanks for your answer! It's indeed the platform designer.
I uploaded two screenshots of the tool I mean:
As you can see there is no such frequency input. Just the timings and it magically works.
