Same Issue on Windows 10, Quartus Lite v21.1. Tried running as administrator but no change. Looked at my anti-virus logs but didn't see anything there either.
OS version:
Edition Windows 10 Pro for Workstations
Version 21H2
Installed on 12/16/2021
OS build 19044.1415
Experience Windows Feature Experience Pack 120.2212.3920.0
Here's an error log with several lines removed for size:
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Error during execution of "{C:/intelfpga_lite/21.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Execution of command "{C:/intelfpga_lite/21.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: child process exited abnormally
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: add_fileset_file: No such file C:/Users/TimK/AppData/Local/Temp/alt8996_4353469586298105083.dir/0004_seq_gen/hps_AC_ROM.hex
Error: border: Error during execution of script generate_hps_sdram.tcl: Generation stopped, 3 or more modules remaining
Error: border: Execution of script generate_hps_sdram.tcl failed
Error: border: 2022.01.04.08:42:45 Info:
Error: border: ********************************************************************************************************************
Error: border:
Error: border: Use qsys-generate for a simpler command-line interface for generating IP.
Error: border:
Error: border: Run ip-generate with switch --remove-qsys-generate-warning to prevent this notice from appearing in subsequent runs.
Error: border:
Error: border: 2022.01.04.08:42:48 Warning: Ignored parameter assignment device=5CSEBA6U23I7
Error: border: 2022.01.04.08:42:48 Warning: Ignored parameter assignment extended_family_support=true
Error: border: 2022.01.04.08:42:53 Warning: hps_sdram: 'Quick' simulation modes are NOT timing accurate. Some simulation memory models may issue warnings or errors
Error: border: 2022.01.04.08:42:53 Warning: hps_sdram.seq: This module has no ports or interfaces
Error: border: 2022.01.04.08:42:53 Warning: hps_sdram.p0: p0.scc must be exported, or connected to a matching conduit.
Error: border: 2022.01.04.08:42:53 Warning: hps_sdram.as: as.afi_init_cal_req must be exported, or connected to a matching conduit.
Error: border: 2022.01.04.08:42:53 Warning: hps_sdram.as: as.tracking must be exported, or connected to a matching conduit.
Error: border: 2022.01.04.08:42:53 Warning: hps_sdram.c0: c0.status must be exported, or connected to a matching conduit.
Error: border: 2022.01.04.08:42:53 Warning: hps_sdram.p0: p0.avl must be connected to an Avalon-MM master
Error: border: 2022.01.04.08:42:53 Info: hps_sdram: Generating altera_mem_if_hps_emif "hps_sdram" for QUARTUS_SYNTH
Error: border: 2022.01.04.08:42:55 Info: pll: "hps_sdram" instantiated altera_mem_if_hps_pll "pll"
Error: border: 2022.01.04.08:42:55 Info: p0: Generating clock pair generator
Error: border: 2022.01.04.08:42:56 Info: p0: Generating hps_sdram_p0_altdqdqs
Error: border: 2022.01.04.08:43:01 Info: p0:
Error: border: 2022.01.04.08:43:01 Info: p0: *****************************
Error: border: 2022.01.04.08:43:01 Info: p0: Remember to run the hps_sdram_p0_pin_assignments.tcl
Error: border: 2022.01.04.08:43:01 Info: p0: script after running Synthesis and before Fitting.
Error: border: 2022.01.04.08:43:01 Info: p0: "hps_sdram" instantiated altera_mem_if_ddr3_hard_phy_core "p0"
Error: border: 2022.01.04.08:43:02 Error: seq: Error during execution of "{C:/intelfpga_lite/21.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: border: 2022.01.04.08:43:02 Error: seq: Execution of command "{C:/intelfpga_lite/21.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: border: 2022.01.04.08:43:02 Error: seq: child process exited abnormally
Error: border: 2022.01.04.08:43:02 Error: seq: add_fileset_file: No such file C:/Users/TimK/AppData/Local/Temp/alt8996_4353469586298105083.dir/0004_seq_gen/hps_AC_ROM.hex
Error: border: while executing
Error: border: "add_fileset_file $file_name [::alt_mem_if::util::hwtcl_utils::get_file_type $file_name 0] PATH $file_pathname"
Error: border: ("foreach" body line 4)
Error: border: invoked from within
Error: border: "foreach file_pathname $return_files_sw {
Error: border: _dprint 1 "Preparing to add $file_pathname"
Error: border: set file_name [file tail $file_pathname]
Error: border: add_fileset_file $..."
Error: border: (procedure "generate_sw" line 18)
Error: border: "generate_sw $name $fileset"
Error: border: ("if" then script line 4)
Error: border: "if {[string compare -nocase $fileset QUARTUS_SYNTH] == 0} {
Error: border: set top_level_file "altera_mem_if_hhp_qseq_synth_top.v"
Error: border: add_fileset_file $top_level_fi..."
Error: border: (procedure "generate_files" line 4)
Error: border: "generate_files $name QUARTUS_SYNTH"
Error: border: (procedure "generate_synth" line 3)
Error: border: "generate_synth altera_mem_if_hhp_qseq_synth_top"
Error: border: 2022.01.04.08:43:02 Info: seq: "hps_sdram" instantiated altera_mem_if_hhp_ddr3_qseq "seq"
Error: border: 2022.01.04.08:43:02 Error: Generation stopped, 3 or more modules remaining
Error: border: 2022.01.04.08:43:02 Info: hps_sdram: Done "hps_sdram" with 7 modules, 33 files
Info: border: "hps_io" instantiated altera_interface_generator "border"
Error: Generation stopped, 2 or more modules remaining
Info: soc_system: Done "soc_system" with 59 modules, 121 files
Error: qsys-generate failed with exit code 1: 66 Errors, 2 Warnings
Info: Finished: Create HDL design files for synthesis
- JWies14 years ago
Hi Tim, hi others, searching for solutions!
At some point some software designer had the brilliant idea that the life of user could become more interesting by using the NIOS tool chain eben for projects not using NIOS. No one will read the additional requirements for the NIOS toolchain when not using NIOS.
I did and installed WSL and Ubuntu on Linux. (See How to install the Windows* Subsystem for Linux* (WSL) on Windows* OS? )
Well, didn't help.Then I found Why do I get an error in Platform Designer ... , this helped.
I don't know if you really need the WSL step. Just in case you do, I leave it in here.
Have a lot of fun.
- TimK4213 years ago
I installed WSL2 with Ubuntu 18.04 and ran the "sudo" commands listed above and everything worked with Altera v21.1
Link for reference: community.intel.com/t5/Intel-Quartus-Prime-Software/Platform-Design-tool-gets-error-when-generating-system-Error/m-p/638649#M59904
As stated before, this has seemed to work for several customers. Thanks Kenny!
