Pack_of_lone_wolves
2 years agoPlacement constraints for PLL in QPP
There is the feature called as logic lock which can fix placement of a node, I want to know if it is possible to use logic lock for fixing position of PLL? I get a warning in plan stage of fitter as "...
- 2 years ago
You can choose "Location" for that version of Quartus Prime.
AqidAyman_Altera
2 years agoFrom my opinion, logic lock will reduce the flexibility for you on the timing side of the design. My suggestion is you need to change the PLL location through the qsf assignments.
Pack_of_lone_wolves
2 years agoWill try this and let you know.
