8 years ago
PISO reg issue
Hello there.
I am trying to implement PISO register with this code (dout and tmp are regs)
always @(posedge sclk)
begin
    if (cs == 0)
    begin
        dout <= tmp;
        tmp <= { tmp , 1'b0 };
    end
end
[15:0] tmp loaded elsewhere. So i need to convert parallel tmp in serial dout. During sim I saw that pic related: dout become tmp on second cycle, why?
Well, seems like i created two regs and they sequentially loaded (on first clk tmp, on second it is given to dout) but how to make them work together? I cannot name tmp "wire", gtkwave give error. Please, help me
    You're using non-blocking assignments. Thus the first assignment is using the "old" value of tmp[15] from the previous cycle. Use blocking assignments (= instead of <=).
    That was helpful!
    But i faced another problem with those shift regs :c
    module shiftreg1 (
                    input  reset,
                    input  clk_i,
                    output sclk_adc,
                    input  din,
                    output dout
    reg  counter = 0;
    reg shiftOut = 16'b1000_1000_1000_1000;
    wire  out_next;
    assign    sclk_adc = counter;
    reg  curr_in = 0;
    wire  shiftIn  = {curr_in, din};
    assign dout = shiftOut ;
    assign out_next = { shiftOut, 1'b0};
    reg    main_reg;
    wire	pos_sclk, neg_sclk;
    assign  pos_sclk = sclk_adc & ~main_reg;
    assign  neg_sclk = ~sclk_adc & main_reg;
    always @(posedge clk_i or posedge reset)
    begin
        counter <= counter +1;
        main_reg <= sclk_adc;
        if (pos_sclk)
            begin
            shiftOut <= out_next;
            end
        if (neg_sclk)
            begin
            curr_in <= shiftIn;
            end
    end
    endmodule
    So, i generated slow clock sclk_adc from main clock, and then need to load regs within posedge and negedge of this sclk_adc. If i simply wrote if (sclk_adc) ... else... my shift regs will load with main clock since this block is posedge clk_i, so i created pos and neg edge detectors which work well enough, but they latched on the next clk after pos_sclk detected, why?
    in this matter change in block/non-block assignments does not affect answer. pls help me to explain this
    is there any way to avoid creating a new always (with sclk_adc event there) blocks?
    https://www.alteraforum.com/forum/attachment.php?attachmentid=15845
    --- Quote Start ---
    --- Quote End ---
    It seems to be latched on the next clk after pos_sclk detected but if you check carefully the posedge clk_i & posedge reset wave then you we will reliase that it is looking for posedge clk_i or posedge reset event when pos_sclk is High.
    Refer the yellow colored cursor portion in the attached screenshot.
    Best Regards
    Vikas Jathar
  • RKing1's avatar
    RKing1
    thanks a lot guys for answering the questions. i really find it very useful but i was wondering if you could answer some of my questions as well? please? anyway thanks for anything so far!
