Pipeline parameter issues for LPM_Divide
I don't know if it makes sense to make a new case for a simaler problem, so im going to right it here
Im facing timing issues like before with "LPM_Divide" but im now using the average (similare to RMS). I have a sample design for adding the data with a PLL output of 250MHz and a register for dividing that PLL output to 125MHz called "clk_2".
"clk_2" is connected to a "valid_register" (for a faster clock domain (PLL output) to another slower clock domain (clk_2)) and LPM_Divide where im facing timing errors.
Here some Infos about my design:
RTL Viewer this Desgin and Timing report attached.
LPM_Divide Parameters:
lpm_drepresentation => "UNSIGNED",
lpm_hint => "MAXIMIZE_SPEED=6,LPM_REMAINDERPOSITIVE=TRUE",
lpm_nrepresentation => "SIGNED",
lpm_pipeline => 12,
lpm_type => "LPM_DIVIDE",
lpm_widthd => 22,
lpm_widthn => 12
SDC file:
set_time_format -unit ns -decimal_places 3
create_clock -name {clk} -period 20.000 -waveform { 0.000 10.000 } [get_ports {clk}]
create_generated_clock -name {DUT0|altpll_component|auto_generated|pll1|clk[0]} -source [get_pins {DUT0|altpll_component|auto_generated|pll1|inclk[0]}] -duty_cycle 50/1 -multiply_by 5 -master_clock {clk} [get_pins {DUT0|altpll_component|auto_generated|pll1|clk[0]}]
create_generated_clock -name clk_2 -source [get_pins {DUT0|altpll_component|auto_generated|pll1|clk[0]}] -divide_by 2 [get_pins {clk_2|q}]
set_clock_uncertainty -rise_from [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] -rise_to [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] 0.020
set_clock_uncertainty -rise_from [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] -fall_to [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] 0.020
set_clock_uncertainty -fall_from [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] -rise_to [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] 0.020
set_clock_uncertainty -fall_from [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] -fall_to [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] 0.020
set_clock_uncertainty -rise_from [get_clocks {clk}] -rise_to [get_clocks {clk}] 0.020
set_clock_uncertainty -rise_from [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] -rise_to [get_clocks {clk}] 0.020
set_clock_uncertainty -rise_from [get_clocks {clk}] -rise_to [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] 0.020
set_clock_uncertainty -rise_from clk_2 -rise_to DUT0|altpll_component|auto_generated|pll1|clk[0] 0.020
set_clock_uncertainty -fall_from clk_2 -rise_to DUT0|altpll_component|auto_generated|pll1|clk[0] 0.020
set_clock_uncertainty -rise_from DUT0|altpll_component|auto_generated|pll1|clk[0] -fall_to clk_2 0.020
set_clock_uncertainty -fall_from clk_2 -rise_to clk_2 0.020
set_clock_uncertainty -fall_from clk_2 -fall_to clk_2 0.020
set_input_delay -add_delay -clock [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] 0.020 [get_ports {ADC_data*}]
set_input_delay -add_delay -clock [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] 0.020 [get_ports {num_adc_data*}]
set_output_delay -add_delay -clock [get_clocks {DUT0|altpll_component|auto_generated|pll1|clk[0]}] 0.020 [get_ports {fifo_wrreq}]
set_output_delay -add_delay -clock [get_clocks {clk_2}] 0.020 [get_ports {mean_result*}]
set_false_path -from [get_ports {reset}]
set_multicycle_path -setup -end -from [get_registers {ADD_res:DUT6|fifo_valid_s}] -to [get_ports {fifo_wrreq}] 2
set_multicycle_path -hold -end -from [get_registers {ADD_res:DUT6|fifo_valid_s}] -to [get_ports {fifo_wrreq}] 1
Any thoughts on how we can manage to control the timing error, I'd appreciate it.
thanks in advance
