12 years agoPipeline latency
Suppose I would like to know how many cycles deep is my kernel pipeline. Is this information readily available from any .log file generated by AOCL? Thank you,
So, I should just stick to the report printed on the stdout?
I can always browse through the quartus project, but since it's an automatically generated project from the OpenCL kernel most of it is not 'user'-readable. Pipeline latency can be an important design parameter to some designs. If a work-item is dispatched for execution each clock cycle, if the pipeline latency is in the same order of magnitude of the number of scheduled work-items it carries a non-negligible effect for the overall FPGA kernel execution throughput, whereas latencies orders of magnitude below the number of work-items scheduled for execution might be neglected. On a given design I obtain the following report: Kernel throughput analysis for : decode .. simd work items : 2 .. compute units : 1 .. throughput due to control flow analysis : 0.48 K work items/second .. kernel global memory bandwidth analysis : 18390.81 MB/second .. kernel number of local memory banks : none +--------------------------------------------------------------------+ ; Estimated Resource Usage Summary ; +----------------------------------------+---------------------------+ ; Resource + Usage ; +----------------------------------------+---------------------------+ ; Logic utilization ; 73% ; ; Dedicated logic registers ; 37% ; ; Memory blocks ; 64% ; ; DSP blocks ; 15% ; +----------------------------------------+---------------------------; This means that for a large number of work-items I can get a throughput of 480 work-items per second, right? This seems too slow for kernel clocks (found in the quartus projects) kernel_clk and kernel_clk2x of 214.13 and 428.27 MHz. Well, the latter is just two times the former. It would make sense to provide more 'hardware' metrics, after all AOCL generates circuits.
