16 years agoI was under the assumption, that the /3GB switch should also help with some graphics problems, but I may be an erroneous believe. Did you also notice the "quartus.ini" solution at the end of the above quoted thread? I have no idea if it's still valid for Quartus 9 and if it has any general meaning. As far as I understand, quartus.ini is a means to provide various undocumented workarounds and Quartus "cheats".
