15 years agopin location AB15 (pad_214) is too close to VREF
Hi all
I meet one error when run Quartus10.1 to implement cyclone4-115-f780 (EP4CE115) Error: Output or bidirectional pin COMMON_I[8] in pin location AB15 (pad_214) is too close to VREF pin in pin location AA15 (pad_213) Error: Output or bidirectional pin COMMON_I[8] in pin location AB15 (pad_214) is too close to VREF pin in pin location AA15 (pad_213) Error: Output or bidirectional pin COMMON_I[14] in pin location AF21 (pad_239) is too close to VREF pin in pin location AC18 (pad_240) Error: Output or bidirectional pin COMMON_I[0] in pin location AD12 (pad_182) is too close to VREF pin in pin location AB13 (pad_181) Error: Output or bidirectional pin COMMON_I[0] in pin location AD12 (pad_182) is too close to VREF pin in pin location AB13 (pad_181) Error: Output or bidirectional pin COMMON_I[0] in pin location AD12 (pad_182) is too close to VREF pin in pin location AB13 (pad_181) Error: Output or bidirectional pin COMMON_I[8] in pin location AB15 (pad_214) is too close to VREF pin in pin location AA15 (pad_213) Error: Output or bidirectional pin COMMON_I[8] in pin location AB15 (pad_214) is too close to VREF pin in pin location AA15 (pad_213) Error: Output or bidirectional pin COMMON_I[8] in pin location AB15 (pad_214) is too close to VREF pin in pin location AA15 (pad_213) ......................................... according to <<EP4CE115 Pin Out.xls>>, PIN_AB15 is next to VREFB4N2(PIN_AA15) I have ever tried to add constraints: set_instance_assignment -name IO_MAXIMUM_TOGGLE_RATE "0 MHz" -to COMMON_I[8] .................................................. but this constraints does not work. so, do you have some suggestion? thanks very much
