12 years ago
pin assignment in Quartus II
I am a beginner . How can we do pin assignment according to device?? How to import file ?which file has to import? what is pin planner?
Anyone please help me .
Thank you
    If you're new to this I recommend you use the Pin Planner tool built into Quartus.
    If you haven't already, run the 'Analysis & Synthesis' on your project.
    Select 'Assignments' -> 'Pin Planner'.
    On the left will be a list of all your top level signal names. Double click the 'Location' cell next to each signal. This will allow you to assign the pin you want.
    Cheers,
    Alex
    thanks sir... Can I get one more Help? I need to get the pin out details of Ep2s60f672c3n as to assign At location box. C an u please suggest me any link for that?
    Thankyou
    In a similar vein, I am trying to understand what ends up in the Assignment Editor after a pin assignment. In my case, I'm using Quartus II 13.1 Web Edition with the DE0-Nano. In the Pin Planner, I assigned the 50MHz clock, resulting in the following:
    Node Name: CLK_50
    Direction: Input
    In the Assignment Editor, this shows up as:
    Status: ? 'To' name unrecognized
    To: CLK_50 (with a question mark icon)
    Assignment Name: Location
    Value: PIN_R8
    Entity: (grayed out)
    However, there's another option in the Assignment Editor for "Assignment Name": external pin connection. In this case, I can enter the following:
    Status: Ok
    To: CLK_50
    Assignment Name: External Pin Connection
    Value: R8
    Entity: (my top-level entity name)
    So which is more correct? It certainly seems like the "External Pin Connection" would be the most accurate, but I cannot seem to find any documentation about when that should be used. And it doesn't quite seem to be associated to the Pin Planner. So now I am just confused.
