12 years agoIn a similar vein, I am trying to understand what ends up in the Assignment Editor after a pin assignment. In my case, I'm using Quartus II 13.1 Web Edition with the DE0-Nano. In the Pin Planner, I assigned the 50MHz clock, resulting in the following:
Node Name: CLK_50 Direction: Input Location: PIN_R8 In the Assignment Editor, this shows up as: Status: ? 'To' name unrecognized To: CLK_50 (with a question mark icon) Assignment Name: Location Value: PIN_R8 Entity: (grayed out) However, there's another option in the Assignment Editor for "Assignment Name": external pin connection. In this case, I can enter the following: Status: Ok To: CLK_50 Assignment Name: External Pin Connection Value: R8 Entity: (my top-level entity name) So which is more correct? It certainly seems like the "External Pin Connection" would be the most accurate, but I cannot seem to find any documentation about when that should be used. And it doesn't quite seem to be associated to the Pin Planner. So now I am just confused.
