12 years agoIf you're new to this I recommend you use the Pin Planner tool built into Quartus.
If you haven't already, run the 'Analysis & Synthesis' on your project. Select 'Assignments' -> 'Pin Planner'. On the left will be a list of all your top level signal names. Double click the 'Location' cell next to each signal. This will allow you to assign the pin you want. Cheers, Alex
