15 years agoPhase lock loop
I want to implement a phase lock loop in fpga , altera(cyclone II). The internal clock is 50 MHZ. but my input clock is 60 HZ. How i should implement pll in this case???
Hi i am implementing phase lock loop in altera cyclone II. I wrote my code in vhdl. My input is 60 Hz analog signal, here are my questions,
1. How i should convert 60 Hz analog to digital signal using vhdl coding? 2. I implemented phase detected and its perfectly finding the phase error and loop filter is also working well finding the measure of phase error. The above two i have implemented in two process. Now comes the difficult situation, when i am using the clock in third process which is digital controlled oscillator, it says that " couldn't implement registers for assignments on this clock edge " . How i should solve this error ??? i tested phase detected and loop filter using 60 Hz digital signal. I want to know converting digital to analog using vhdl coding?
