--- Quote Start ---
Basically yes. You have to care, that the digital input, e.g. sourced from a comparator, doesn't produce multiple edges. A phase detector, that evaluates the fundamental of the input signal (e.g. "Nyquist rate") or averages the sign (XOR phase-detector, e.g. page 080-27) would be more robust against distorted input signals.
--- Quote End ---
So instead of Jk flip flop , i can go ahead with XOR PHASE-DETECTOR right?
My input is 60 Hz (variable) analog signal. In the block diagram i have few questions, since my input is 60 HZ
1. how i should choose my fC(INPUT to variable N counter)
2. Can explain the digital controlled oscillator part?
Ur help is really appreciated.
