Altera_ForumHonored Contributor15 years agoPhase lock loop I want to implement a phase lock loop in fpga , altera(cyclone II). The internal clock is 50 MHZ. but my input clock is 60 HZ. How i should implement pll in this case???
Altera_ForumHonored Contributor15 years ago --- Quote Start --- Since my input is in 60 Hz will below PDF block diagram works for me to get synchronization of the input. http://users.ece.gatech.edu/~jskenney/l080-adpll(2up).pdf (http://users.ece.gatech.edu/%7ejskenney/l080-adpll%282up%29.pdf) In attached pdf on (page 080-18) example 1 . Kindly help me
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
