PFL configuration Arria ii GX
Hello
I m Newbie
I am trying to configure EP2AGX Arria® II GX using EPM240 Max ii CPLD and on board CFI Flash js28f256m29ewh using PFL IP.
In my case our custom Board flash Address bus 24bit bus and Data 8bit Bus from FPGA conected as per PFL requirement
but in case of CPLD only connected with 24bit Addresses to Flash and Data bus is not contected between CPLD and CFI Flash
below picture as shown
my question is
1.how configure PFL for CFI flash program from CPLD ?
2.can i program by using PFL from FPGA ?
What will the best option for me please help us.
Nome
- NurAiman_M_Intel
We would recommend you to refer to Intel FPGA PFL userguide below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
Let us know if you have any concern.
Aiman
- nome
Hi
Sir
Thanks for your reply
In my case I wrote my above post our custom board doesn't have directly CPLD to CFI data port there
thats why I am confused how to define PFL_flash_data [0] to PFL_flash_data[7] in PFL? CFI flash D15 also connected with CPLD.
PFL_flash_addr[0] to PFL_flash_addr[24] CPLD to CFI connected there
all require another pin connected between CPLD and CFI Flash like nce,we,oe etc
Nome
- nome
Hello
i have found 10 more pins between cpld and fpga
i am totally confused
how configure PFL
as in ug_pfl. pdf i couldn't find out how configure if we don't have data bus between cfi and cpld
please help me
thank
nome
- NurAiman_M_Intel
Hi Nome,
No connection is needed between Arria II and flash, this is because it will be control by PFL and CPLD(Max 10) to load in Arria II.
Aiman
- nome
Hello
sir i am not talking about connection between Arria fpga and flash.
I am talking about data bus between cpld max II and flash
if we doesn't have physically data bus between Max II and flash how pfl will work?
nome
- nome
Hello
I m new in parallel Flashing
I want to know Regarding NIOS processor Flashing How to make Boot by using PFL?
what will Roll of CPLD?
How to Flashing Boot Area after it will able to using NIOS Flashing
I am totally confused
Our hardware is Arria II GX and and CPLD MAX II js28f256m29ewh Flash
Nome
