PCIe IP example error: Failed to open design unit file "../../../top_core.vo" in read mode.
I tried shortening the directory to which Quartus restores the .qar file to just "D:/c/", but I still get this error:
# Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct 5 2016
# Start time: 23:43:27 on Jul 30,2019
# vlog -reportprogress 300 "+incdir+../../common/testbench/+../../common/incremental_compile_module+.." -work work ../../../top_core.vo
# ** Error: (vlog-7) Failed to open design unit file "../../../top_core.vo" in read mode.
# No such file or directory. (errno = ENOENT)
# End time: 23:43:27 on Jul 30,2019, Elapsed time: 0:00:00
# Errors: 1, Warnings: 0
# ** Error: D:/intelFPGA_lite/18.1/modelsim_ase/win32aloem/vlog failed.
# Error in macro ./runtb.do line 115
# D:/intelFPGA_lite/18.1/modelsim_ase/win32aloem/vlog failed.
# while executing
# "vlog +incdir+../../common/testbench/+../../common/incremental_compile_module+.. -work work $vfile"
# ("while" body line 2)
# invoked from within
# "while {[gets $simlist vfile] >= 0} {
# vlog +incdir+../../common/testbench/+../../common/incremental_compile_module+.. -work work $vfile
# ("eval" body line 3)
# "_comp"
anything else i can try? can you send me the correct top_core.vo file directly?
- AnandRaj_S_Intel7 years ago
Yes, I have able to replicate the scenario attached modelsim error log.
Let me check and come back.
Anand
- MMorr237 years ago
Any update?
Still working on it.
we will update you soon.
Sorry for the inconvenience caused.
Hi, is there any update? Please help
