You'll have to alter two files :
<variation>_serdes.vhd
signal_detect_hysteresis => 4,
signal_detect_hysteresis_valid_threshold => 14,
signal_detect_loss_threshold => 3,
<variation>_examples\chaining_dma\db\altpll_sc81.tdf ...
VARIABLE
pll1 : cycloneiv_pll
WITH (
BANDWIDTH_TYPE = "high",
CLK0_DIVIDE_BY = 2,
CLK0_MULTIPLY_BY = 25,
CLK1_DIVIDE_BY = 10,
CLK1_MULTIPLY_BY = 25,
CLK2_DIVIDE_BY = 10,
CLK2_DUTY_CYCLE = 20,
CLK2_MULTIPLY_BY = 25,
DPA_DIVIDE_BY = 2,
DPA_MULTIPLY_BY = 25,
INCLK0_INPUT_FREQUENCY = 10000,
OPERATION_MODE = "no_compensation"
Let me know if this is working. Normally it should compile and synthesize now. Bust when you'll run the generated chaining_dma testbench in ModelSim it will run but you'll get messages telling you again : CLK0_DIVIDE_BY should be more then '0'.
I'm not really sure if it's a 100 % solution ...
