Hi!
Thank you for the tip, but when i compile the example (chaining_dma) i get the same errors:
Error: PLL "PCIe_example_chaining_pipen1b:core|PCIe_plus:ep_plus|PCIe:epmap|PCIe_serdes:serdes|PCIe_serdes_alt_c3gxb_0eb8:PCIe_serdes_alt_c3gxb_0eb8_component|altpll:pll0|altpll_ld81:auto_generated|pll1" has port CLK connected but parameters clk0_multiply_by and/or clk0_divide_by are either unspecified or set to 0
Error: PLL "PCIe_example_chaining_pipen1b:core|PCIe_plus:ep_plus|PCIe:epmap|PCIe_serdes:serdes|PCIe_serdes_alt_c3gxb_0eb8:PCIe_serdes_alt_c3gxb_0eb8_component|altpll:pll0|altpll_ld81:auto_generated|pll1" has port CLK connected but parameters clk1_multiply_by and/or clk1_divide_by are either unspecified or set to 0
Error: PLL "PCIe_example_chaining_pipen1b:core|PCIe_plus:ep_plus|PCIe:epmap|PCIe_serdes:serdes|PCIe_serdes_alt_c3gxb_0eb8:PCIe_serdes_alt_c3gxb_0eb8_component|altpll:pll0|altpll_ld81:auto_generated|pll1" has port CLK connected but parameters clk2_multiply_by and/or clk2_divide_by are either unspecified or set to 0
Can you post your settings?
