13 years ago
Pcie bfm
Hi, greetings!
I am using Quartus 11.0 sp1. I need the PCIE BFM for qsys based pcie design simulation. Searching through the forum, look like bfm is removed from qsys generation since 11.0. So I grabbed one copy from quartus 11.0. So far so good, but when I ran the simulation, it can run all the way past memory read/write test, and stuck in DMA test. I am guessing the BFM from 11.0 might need a little bit tune up to be used in 11.0sp1. Anyone here knows how to fix it?
Thanks!
# INFO: 47968 ns BAR Address Assignments:
# INFO: 47968 ns BAR Size Assigned Address Type
# INFO: 47968 ns --- ---- ----------------
# INFO: 47968 ns BAR1:0 128 MBytes 00000001 00000000 Prefetchable
# INFO: 47968 ns BAR2 128 MBytes 08000000 Non-Prefetchable
# INFO: 47968 ns BAR3 Disabled
# INFO: 47968 ns BAR4 Disabled
# INFO: 47968 ns BAR5 Disabled
# INFO: 47968 ns ExpROM Disabled
# INFO: 50048 ns
# INFO: 50048 ns Completed configuration of Endpoint BARs.
# INFO: 51664 ns Starting Target Write/Read Test.
# INFO: 51664 ns Target BAR = 0
# INFO: 51664 ns Length = 000512, Start Offset = 000000
# INFO: 58488 ns Target Write and Read compared okay!
# INFO: 58488 ns Starting DMA Read/Write Test.
# INFO: 58488 ns Setup BAR = 2
# INFO: 58488 ns Length = 000512, Start Offset = 000000
# FATAL: 400000 ns Simulation stopped due to inactivity!
# FAILURE: Simulation stopped due to Fatal error!
# FAILURE: Simulation stopped due to error!
