JWrig25
6 years agoPCI Express Avalon-MM High-Performance DMA Reference Design for Stratix V does not compile.
The compilation of the PCI Express Avalon-MM High-Performance DMA Reference Design for Stratix V fails in Quartus Prime Standard Edition 18.1. The errors say that the IP components need to be upgrade...
BoonT_Intel
6 years agois it a QAR or a zip file? If zip, you can open the QSF file and check the version used.
If QAR, once you able to open with quartus, you also can open the QSF to check.
JWrig25
6 years agoThe Avalon-MM design file is a .QAR zip file.
