11 years ago
PCI-E DMA Failure
Hi folks,
I run into a problem using Altera OpenCL and the Nallatech PCI-E 385N under Windoze. Everything works as intended and data is valid when using the AMD OpenCL SDK under Linux with the exact same code.
Has anyone ever got this error while writing a buffer? Got a clue for me?
MMD FATAL: acl_pcie_dma_windows.cpp: WDC_DMASGBufLock function failed.
Thanks in advance!
Edit: BTW, does someone know when the 14.1 software is going to be released? It was happening in November in the past...
