m_kumarOccasional Contributor5 years agoPath Violation in timing analyzer Hi , Iam working max10 fpga , in timing analyzer i'm getting path violations can i get any help to solve this problem. Report Timing: Found 200 setup paths (200 violated). Worst case slack is -0....Show More
SyafieqSSuper Contributor5 years agoHi Manoj,Maybe some information (sdc, timing report) to evaluate the issue here needed
m_kumarOccasional Contributor to SyafieqS5 years agoHi sir thanks for the reply i reached the desired timing . Problem was in my sdc file timing values.
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportSolvedFailed to run ip-setup-simulation:ModelSim/Questa does not include external IP repo filesQuartus Lite 23.1 MAX 10 EncryptionMailbox Client IP - SEND_CERTIFICATE command through FPGA fabric
