MBisi3's avatar
MBisi3
7 years ago
Passing tcl script variables to qsf file
I am looking to execute a tcl script at the beginning of the flow using
set_global_assignment -name PRE_FLOW_SCRIPT_FILE "quartus_sh:first.tcl"
in this script I create a variable that should be evaluated inside qsf; I would like to be able to write, in qsf, a line such as:
set_parameter -name MYVARIABLE = $tclscriptcreatedvariable
unfortunately this syntax throw an error while starting compile and also removing "=" the same.
How can I obtain this result without rewriting qsf file from tcl ? Is it possible to have qsf file to include an external file setting some parameters ?
Thank you for your support
Marco Bisio
