MBisi3
7 years agoPassing tcl script variables to qsf file
I am looking to execute a tcl script at the beginning of the flow using set_global_assignment -name PRE_FLOW_SCRIPT_FILE "quartus_sh:first.tcl" in this script I create a variable that should be eva...
KhaiChein_Y_Intel
7 years agoHi,
You may add the following command before the set_parameter -name GVAR = $myvariable
project_open <project_name>
- MBisi37 years ago
Hello YY, I tried the solution you give me and it works. Unfortunately, this way, I am unable to write a generic script working for each project I have. I have also one more issue: the generic map is defined using one generic inside another one. This should be supported in VHDL 2008, and I configured input files this way. Unfortunately quartus II throw an error: Error (10552): VHDL expression error at test.vhd(13): illegal GVERSIONLEN in expression Error (10556): VHDL error at test.vhd(12): generic "GVERSIONLEN" cannot be used in its own interface list Error: Quartus Prime Analysis & Synthesis was unsuccessful. 2 errors, 1 warning Error: Peak virtual memory: 4787 megabytes Error: Processing ended: Wed Oct 02 18:28:22 2019 Error: Elapsed time: 00:00:12 Error: Total CPU time (on all processors): 00:00:23 Error (293001): Quartus Prime Full Compilation was unsuccessful. 4 errors, 1 warning In attach you will find a test project to replicate this issue. Thank you. Marco Bisio Marco Bisio [cid:[email protected]] Via per Vallalta – S.P.7 41033 Concordia sulla Secchia (MO) IT GPS: 44.925679 N, 10.998667 E tel: +39 0535 40818 fax: +39 0535 55044 mob: +39 3456557427 E-mail: [email protected]<mailto:[email protected]> www.topconinfomobility.com<http://www.topconinfomobility.com/> Le informazioni contenute in questo messaggio e gli eventuali allegati sono riservati e destinati esclusivamente ad uno o più specifici destinatari sopra indicati. I messaggi di posta elettronica non sono sicuri e possono essere soggetti ad alterazioni, trasmettitori di Virus informatici o soggetti a ritardi nella distribuzione. Il mittente del messaggio non può essere in alcun modo considerato responsabile per queste evenienze. Qualora non siate i destinatari del messaggio, Vi chiediamo di non farne uso, né copia, né comunicazione a terzi di quanto in esso contenuto ai sensi dell'art. 616 c.p. e del D.Lgs n. 196/2003. Se questa comunicazione Vi è pervenuta per errore, Vi chiediamo gentilmente di cancellare il presente messaggio. The information contained in this electronic message and any attachment is intended for one or more specific individuals to whom it is addressed. Electronic messages are not secure or error free and can contain viruses or may be delayed, and the sender is not liable for any of these occurrences. If you are not the intended recipient, please notify the sender immediately, delete this message and do not disclose, distribute, or copy it to any third party or otherwise use this message as per art. 616 Criminal Code and Legislative Decree 196/03 of Italian law. If you are not the intended recipient, please remove it from your system. Da: Intel Forums <[email protected]> Inviato: martedì 1 ottobre 2019 08:34 A: Marco Bisio <[email protected]> Oggetto: YY answered you: Passing tcl script variables to qsf file Hi, You may add the following command before the set_parameter -name GVAR = $myvariable project_open <project_name> Thanks. [Immagine rimossa dal mittente.]<https://urldefense.proofpoint.com/v2/url?u=https-3A__forums.intel.com_0050P000008IfXG-3FfromEmail-3D1-26s1oid-3D00DU0000000YT3c-26s1nid-3D0DB0P000000U1Hq-26s1uid-3D0050P000008WtlB-26s1ext-3D0-26emkind-3DchatterCommentNotification-26emtm-3D1569911668062&d=DwMFaQ&c=-0XTxx5JZxtPyuSXdvX8qQ&r=014XRNpUVBAI_GH1TkTES5u8gLdWVINf-JbJIDX4Clo&m=miOvYygTNgsCdetdMWjqtZT24hOw-Bfh0pqSSUR9HJQ&s=v0BLbLug19rj4CFsBF0YWyGhrHTF8zFqdHRxI5veCCw&e=> YY<https://urldefense.proofpoint.com/v2/url?u=https-3A__forums.intel.com_0050P000008IfXG-3FfromEmail-3D1-26s1oid-3D00DU0000000YT3c-26s1nid-3D0DB0P000000U1Hq-26s1uid-3D0050P000008WtlB-26s1ext-3D0-26emkind-3DchatterCommentNotification-26emtm-3D1569911668062&d=DwMFaQ&c=-0XTxx5JZxtPyuSXdvX8qQ&r=014XRNpUVBAI_GH1TkTES5u8gLdWVINf-JbJIDX4Clo&m=miOvYygTNgsCdetdMWjqtZT24hOw-Bfh0pqSSUR9HJQ&s=v0BLbLug19rj4CFsBF0YWyGhrHTF8zFqdHRxI5veCCw&e=> (Intel) Hi, You may add the following command before the set_parameter -name GVAR = $myvariable project_open <project_name> Thanks. [Rettangolo con angoli arrotondati: View/Answer] or reply to this email Replying to [Immagine rimossa dal mittente.]<https://urldefense.proofpoint.com/v2/url?u=https-3A__forums.intel.com_0050P000008WtlB-3FfromEmail-3D1-26s1oid-3D00DU0000000YT3c-26s1nid-3D0DB0P000000U1Hq-26s1uid-3D0050P000008WtlB-26s1ext-3D0-26emkind-3DchatterCommentNotification-26emtm-3D1569911668062&d=DwMFaQ&c=-0XTxx5JZxtPyuSXdvX8qQ&r=014XRNpUVBAI_GH1TkTES5u8gLdWVINf-JbJIDX4Clo&m=miOvYygTNgsCdetdMWjqtZT24hOw-Bfh0pqSSUR9HJQ&s=846rCQwcoHHvmWoik7h8lvnrQc9gQesTIMUT65arxuQ&e=> MBisi3<https://urldefense.proofpoint.com/v2/url?u=https-3A__forums.intel.com_0050P000008WtlB-3FfromEmail-3D1-26s1oid-3D00DU0000000YT3c-26s1nid-3D0DB0P000000U1Hq-26s1uid-3D0050P000008WtlB-26s1ext-3D0-26emkind-3DchatterCommentNotification-26emtm-3D1569911668062&d=DwMFaQ&c=-0XTxx5JZxtPyuSXdvX8qQ&r=014XRNpUVBAI_GH1TkTES5u8gLdWVINf-JbJIDX4Clo&m=miOvYygTNgsCdetdMWjqtZT24hOw-Bfh0pqSSUR9HJQ&s=846rCQwcoHHvmWoik7h8lvnrQc9gQesTIMUT65arxuQ&e=> (Customer) asked a question. Thursday, 26 September 2019 11.11<https://urldefense.proofpoint.com/v2/url?u=https-3A__forums.intel.com_0D50P00004SWuMg-3FfromEmail-3D1-26s1oid-3D00DU0000000YT3c-26s1nid-3D0DB0P000000U1Hq-26s1uid-3D0050P000008WtlB-26s1ext-3D0-26emkind-3DchatterCommentNotification-26emtm-3D1569911668062-26OpenCommentForEdit-3D1&d=DwMFaQ&c=-0XTxx5JZxtPyuSXdvX8qQ&r=014XRNpUVBAI_GH1TkTES5u8gLdWVINf-JbJIDX4Clo&m=miOvYygTNgsCdetdMWjqtZT24hOw-Bfh0pqSSUR9HJQ&s=6aDQibudtJaMnXcbyI2zNVXzqMe4SphElwFTYE-wUsw&e=> Passing tcl script variables to qsf file I am looking to execute a tcl script at the beginning of the flow using set_global_assignment -name PRE_FLOW_SCRIPT_FILE "quartus_sh:first.tcl" in this script I create a variable that should be evaluated inside qsf; I would like to be able to write, in qsf, a line such as: set_parameter -name MYVARIABLE = $tclscriptcreatedvariable unfortunately this syntax throw an error while starting compile and also removing "=" the same. How can I obtain this result without rewriting qsf file from tcl ? Is it possible to have qsf file to include an external file setting some parameters ? Thank you for your support Marco Bisio [Immagine rimossa dal mittente.]<https://urldefense.proofpoint.com/v2/url?u=https-3A__forums.intel.com_0050P000008IfXG-3FfromEmail-3D1-26s1oid-3D00DU0000000YT3c-26s1nid-3D0DB0P000000U1Hq-26s1uid-3D0050P000008WtlB-26s1ext-3D0-26emkind-3DchatterCommentNotification-26emtm-3D1569911668062&d=DwMFaQ&c=-0XTxx5JZxtPyuSXdvX8qQ&r=014XRNpUVBAI_GH1TkTES5u8gLdWVINf-JbJIDX4Clo&m=miOvYygTNgsCdetdMWjqtZT24hOw-Bfh0pqSSUR9HJQ&s=v0BLbLug19rj4CFsBF0YWyGhrHTF8zFqdHRxI5veCCw&e=> YY<https://urldefense.proofpoint.com/v2/url?u=https-3A__forums.intel.com_0050P000008IfXG-3FfromEmail-3D1-26s1oid-3D00DU0000000YT3c-26s1nid-3D0DB0P000000U1Hq-26s1uid-3D0050P000008WtlB-26s1ext-3D0-26emkind-3DchatterCommentNotification-26emtm-3D1569911668062&d=DwMFaQ&c=-0XTxx5JZxtPyuSXdvX8qQ&r=014XRNpUVBAI_GH1TkTES5u8gLdWVINf-JbJIDX4Clo&m=miOvYygTNgsCdetdMWjqtZT24hOw-Bfh0pqSSUR9HJQ&s=v0BLbLug19rj4CFsBF0YWyGhrHTF8zFqdHRxI5veCCw&e=> (Intel) Hi, You may add the following command before the set_parameter -name GVAR = $myvariable project_open <project_name> Thanks. Tuesday, 1 October 2019 7.34<https://urldefense.proofpoint.com/v2/url?u=https-3A__forums.intel.com_0D70P000006Ul5C-3FfromEmail-3D1-26s1oid-3D00DU0000000YT3c-26s1nid-3D0DB0P000000U1Hq-26s1uid-3D0050P000008WtlB-26s1ext-3D0-26emkind-3DchatterCommentNotification-26emtm-3D1569911668062&d=DwMFaQ&c=-0XTxx5JZxtPyuSXdvX8qQ&r=014XRNpUVBAI_GH1TkTES5u8gLdWVINf-JbJIDX4Clo&m=miOvYygTNgsCdetdMWjqtZT24hOw-Bfh0pqSSUR9HJQ&s=ZAoNcA69swhGU-XBbLIzDSC5-Oke-N7chAeNT2kpZ5k&e=> You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in<https://urldefense.proofpoint.com/v2/url?u=https-3A__forums.intel.com_-5Fui_core_feeds_notification_ChatterEmailSettings-3Fsetupid-3DCollaborationEmailSettings-26fromEmail-3D1-26s1oid-3D00DU0000000YT3c-26s1nid-3D0DB0P000000U1Hq-26s1uid-3D0050P000008WtlB-26s1ext-3D0-26emkind-3DchatterCommentNotification-26emtm-3D1569911668062&d=DwMFaQ&c=-0XTxx5JZxtPyuSXdvX8qQ&r=014XRNpUVBAI_GH1TkTES5u8gLdWVINf-JbJIDX4Clo&m=miOvYygTNgsCdetdMWjqtZT24hOw-Bfh0pqSSUR9HJQ&s=ElTavSlACxsLm-RpEzSWe_WlVRMd6pBzKOInWXBvaMA&e=> as [email protected]. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Immagine rimossa dal mittente. Forums] Confidentiality Notice: This message (including attachments) is a private communication solely for use of the intended recipient(s). If you are not the intended recipient(s) or believe you received this message in error, notify the sender immediately and then delete this message. Any other use, retention, dissemination or copying is prohibited and may be a violation of law, including the Electronic Communication Privacy Act of 1986.
