Passed "Design Analysis" stage but failed with "Analysis & Synthesis" stage
Hi There,
I am using Quartus 22.3/22.4 version to compile my design.
My design contains many folders and many source code, including *.svh files.
I am using quartus_sh to run a tcl file to do the compile.
I have added SERACH_PATH and Source code in the tcl file, I can even pass the "Design Analysis" stage with no errors. If my understanding is correct, this at least shows I have include all the files.
However, I got a bunch of "Can't elaborate user hierarchy ***" errors in the "Analysis & Synthesis" stage. Can someone give me some suggestion what I am missing? Does the compile file list order matter? I am sure I did not miss any files otherwise I cannot pass the quick-elab check.
Any suggestions?
Thank you so much!
-Shu
- ShengN_altera
I don't think the compile file list order matter. In gui, may be you can go to Project -> Generate Tcl File for Project. Then in auto-generated tcl script add two lines below:
package require ::quartus::flow
execute_flow -compile
After running auto-generated tcl script, if there's no error then probably there's some problems with your tcl script so can do the comparison. If there's error with auto-generated tcl script as well, then probably the problem is in the design files.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer.
- jeffshh056
Hi Sheng,
My teammate who is using Quartus in GUI mode and got the same issue.
I am using quartus_sh, and I have package require ::quartus::flow in my TCL file. The flow actually runs but errors out.
Info: Run task: IP Generation (pass)
Info: Run task: Design Analysis(pass)
Info: Run task: Logic Generation(pass)
Info: Run task: Analysis & Synthesis(51 errors)
Error (16045): Instance "u_axi_bridge" instantiates undefined entity "axi_bridge" File: #######/src/xyz_ctl.sv Line: 2328
Error (16185): Can't elaborate user hierarchy "u_axi_bridge" File: ######/src/xyz_ctl.sv Line: 2328What puzzles me is that
- I do see the design "axi_bridge" gets compiled, I don't see compile error related to that module, why it can't elaborate?
I am attaching the syn.elab log file here, can you help take a look?
-Shu
- ShengN_altera
Hi Shu,
I think that's not the problem of tcl script then. Check in the axi_bridge.sv, make sure the module name is the same matched name axi_bridge. Same goes for the rest of undefine entity.
Sheng
- jeffshh056
One more observation, if I change to "MFCU" mode, the synth do starts!!!
set_global_assignment -name VERILOG_CU_MODE MFCU
Do you happen to know why it make such difference, does it have anything to do with AUTO-DISCOVERY?
- ShengN_altera
Hi Shu,
Check this link https://www.intel.com/content/www/us/en/docs/programmable/683463/22-4/verify-verilog-compilation-unit.html
Actually Quartus Pro Edition use Single-file compilation unit (SFCU) method to select compilation unit files which is better method compared to Multi-file compilation unit (MFCU) method.
I don't think that would be the root cause. It's better to check whether the module name match or not.
BRs,
Sheng
- ShengN_altera
Hi Shu,
Any further update or concern?
Does your problem being resolved?
