jeffshh056
3 years agoPassed "Design Analysis" stage but failed with "Analysis & Synthesis" stage
Hi There,
I am using Quartus 22.3/22.4 version to compile my design.
My design contains many folders and many source code, including *.svh files.
I am using quartus_sh to run a tcl file to ...
ShengN_altera
3 years agoHi Shu,
I think that's not the problem of tcl script then. Check in the axi_bridge.sv, make sure the module name is the same matched name axi_bridge. Same goes for the rest of undefine entity.
Sheng
jeffshh056
3 years agoOne more observation, if I change to "MFCU" mode, the synth do starts!!!
set_global_assignment -name VERILOG_CU_MODE MFCU
Do you happen to know why it make such difference, does it have anything to do with AUTO-DISCOVERY?
