MinzhiWang
2 years agoPartition export issue when design block reusing was used
Hi guys, I encounter one issue when i export design partion. A message window was popped as follow iamge, then the Quartus action was stopped. Our QPP version is 23.4, and device is 10CX220Y...
- 2 years ago
Ya, probably there's problem at the database qdb folder. Try prepare a copy of the design and clean the project to remove the database, then make sure compile again with v23.4, and then finally export. Let me know if the problem still exists.
Sheng
ShengN_altera
2 years agoHi,
May be go to Project -> Clean Project, does the problem still exists?
Sheng
MinzhiWang
2 years agoHi Sheng,
Why you recommend me cleaning project? If I clean project, I will lose the previous compilation result. So I have to re-compile my project.
Besides cleaning project, I even deleted all folders which are generated during compliation. However, the same issue will appear.
