15 years ago
Partial device AS programming
I want to program 1.4MB compressed sof file into 2MB EPCS16 device by means of Active Serial mode of Quartus Programmer. The point is - I want to program only relevant flash sectors (up to address 160000H) and preserve the rest of the EPCS flash contest. So far I don't even now where to start - "convert programming files" tool insists on creating full 2MB POF file and not a single byte less. I tried both "Add SOF data" and "Add HEX data" variants but as long as EPCS16 is chosen as a target the result is always the same.
Some pointers? GUI, Quartus tcl scripts Nios2 EDS command line tools, I'd take any option.
    The "compression" flag has to be checked explicitely in the individual image file options. It's set independant of the *.sof compression state.
    I know.
    To repeat what I said above, it happens even when I "add to POF" the HEX data which size I know very well. The problem is in conversion to POF rather than in data itself.
    Yes, you are right. The conversion tool always creates a file of full device size. Up to Quartus 9.0, the Quartus programmer uses a chip erase command rather than erasing individual pages. It's been said in the forum, that starting with Q9.1, individual pages are erased, but I'm not aware of the detail implications.
