parameter passing for IP in Platform Designer (Qsys)
I have a design which was originally done in Quartus 15.1. We passed some parameters into QSys (now Platform Designer) for configuration of the altera_pcie_256_hip_avmm IP. I have recently moved the design forward to version 19 but get errors that seem to imply that I either can’t pass parameters into QSys anymore or that maybe the parameter name changed.
The original code had the PCIe_DEVID defined as a parameter in a wrapper verilog file. Later on in the same verilog file, there is a defparam followed by the instantiation of the qsys system. This worked for Quartus 15 but does not work for Quartus 19
defparam u0.PCIE_DEVID=PCIE_DEVID
mySystem_qsys u0 (
// port connections
Inside the qsys system is the altera_pcie_256_hip_avmm IP which has the field for the PCI device ID that I am trying to set.
The error I receive is:
"12077 Node instance "u0" instantiated with unknown parameter "PCIE_DEVID".
Its almost as if either the name of the parameter field changed in the IP block or maybe defparam has been deprecated. I tried using Instance Parameters for passing into the qsys system that was unsuccessful.
Can you help me with the proper syntax to accomplish what used to work with Quartus 15?
- SengKok_L_Intel
What is this device? Are you using AVST or AVSM?
Regards -SK
- MSchn21
The device is Stratix V and the bar space interface is memory mapped. I don't think these matter. I contacted local FAE about the issue. They are checking on whether it is possible to pass parameters into an instantiated QSys system. Our prior workaround has been to post-process the synthesized verilog file that is created after QSys generation step. The post-processing adds code for the parameters. FAE is checking to see if there is a more elegant way than post-processing with script.
- SengKok_L_Intel
This is glad to see there is good progress and the FAE is helping you now.
Regards -SK
- SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
