12 years agoparallel port programming via PC
Hello
In my sdudy final project I use CPLD in order to make some operations. I control the cpld via the computer parallel port. Because the port is not bidirectional, but requires a time open it in any direction I have some problem. When I do a reading or writing separately everything works .. Because I think the CPLDvworks faster than the computer I get inconsistent results. Attached code, if anyone has comments it really helps. In the PC side I am using C language: VHDL Code: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity Dvir is port( sig_in : in std_logic; sig_buff : buffer std_logic; clk : buffer std_logic; data : inout std_logic_vector(7 downto 0); testdata : out std_logic_vector(7 downto 0); strobe : in std_logic; --active high --resetn : in std_logic; --active low ack : out std_logic; --active high testLed : out std_logic --est1 : out std_logic ); end Dvir; architecture Behave of Dvir is signal inData :std_logic_vector(7 downto 0); signal outData :std_logic_vector(7 downto 0); signal intClk :std_logic; signal intCnt :std_logic_vector(19 downto 0); signal intFlag :std_logic; begin --architecture testLed <= intFlag; testdata <=outData; data<= outData when strobe='0' else (others =>'Z'); ack <= '0' when strobe='0' else '1'; d:process(strobe) begin if strobe='0' and strobe'event then --cpld write outData<= not inData; end if; end process d; wr:process(strobe) begin if strobe='1' and strobe'event then --cpld read inData<= data; end if; end process wr; end Behave; Thanks!
