16 years agoI don't think it's a Quartus bug. Actually the "RESET CONTROL SIGNALS" related action in the asynchronous process defines ambigious logic. You have e.g.
LOADRDR<='0';
WHEN RECV_DATA =>
NEXTSTATE<=IDLE;
LOADRDR<='1'; In other words LOADADR is set for "no time", so the output data are never written to the output port. Similar things happen most likely to the other outputs. I didn't check, how the design result with Stratix III behaves, but it can't be as intended, I fear.
