17 years agoMy previous statement wasn't fully correct. Pins not assigned to a design top port are treated according to the designs unused pin rule, but not reported with the said stuck-to message. The message appears with port pins driven intentionally or unintentionally by a constant driver. If the output is expected not to have constant output, the logic should be corrected.
