17 years ago --- Quote Start --- Why are those pins stuck at VCC when I did not assign any pins yet. --- Quote End --- Very unlikely. You get this message for pins, that have been assigned but are not driven by logic. Either you connected no logic to the pin or the connected logic has a constant output. The purpose of the warning is making you check for logic that has unintentional constant output.
