Hello pancake,
Thanks for the quick response. Yes, I have simulated quite a bit with varing combinations of operands and operand sizes. The results are pretty consistant. I also used the RTL Viewer to verify that Quartus II quit synthesizing after two layers past the operand size.
I wouldn't be surprised if there were bugs in my code but I just haven't been able to find them. I have a fair amount of experience programming in C/C++ and Java but this is my first exposure to an HDL and it has taken some getting used to. I did attach the package code to the original posting but here it is again:
library ieee;
use ieee.std_logic_1164.all;
--use ieee.std_logic_signed.all;
package mult_package is
-- constant n: integer := 7;
function "*"(signal multer, multand: std_logic_vector)
return std_logic_vector;
end package mult_package;
package body mult_package is
function "*"(
return std_logic_vector is
type mult_matrix is array (0 to multer'length + multand'length-1)
of std_logic_vector(multer'length + multand'length-1 downto 0);
variable a, b, c: mult_matrix;
variable prod: std_logic_vector(multer'length + multand'length-1 downto 0);
begin
-------- initialize first row in multiplication matrix --------------
if ((multer(0) xor multer(multer'left)) = '1') then
b(0)(b(0)'left downto multand'length) := (others => multand(multand'left));
b(0)(multand'left downto 0) := multand;
else
b(0) := (others => '0');
end if;
a(0) := (others => '0');
c(0) := (others => '0');
prod(0) := b(0)(0);
-------- load multiplicand matrix and generate products -------------
for j in 1 to multer'left loop
if((multer(j) xor multer(multer'left)) = '1') then
a(j)(a(j)'left downto multand'length) := (others => multand(multand'left));
a(j)(multand'left+j downto j) := multand;
else
a(j) := (others => '0');
end if;
for i in j to multand'length+j loop
b(j)(i) := a(j )(i) xor b(j-1)(i) xor c(j-1)(i-1);
c(j)(i) := (a(j )(i) and b(j-1)(i))
or (a(j )(i) and c(j-1)(i-1))
or (b(j-1)(i) and c(j-1)(i-1));
end loop;
prod(j) := b(j)(j);
end loop;
--------------------- final carry propagation -----------------------
for j in multer'length to b'high loop
b(j)(b(j)'high downto j) := b(j-1)(b(j-1)'high downto j) xor c(j-1)(c(j-1)'high-1 downto j-1);
c(j)(c(j)'high downto j) := b(j-1)(b(j-1)'high downto j) and c(j-1)(c(j-1)'high-1 downto j-1);
prod(j) := b(j)(j);
end loop;
--return "00" & prod & "00" & a(n) & "00" & c(n-1) & "00" & b(n) & "00" & c(n);
return prod;
end function "*";
end package body mult_package;
There are a couple lines of debug code included and commented out.
The sythesizer seems to quit after two iterations of the second loop.
Thanks again for your reply and your interst.
Dave
