Altera_ForumHonored Contributor16 years agoOut of memory of quartus_map.exe i get an error when i do compilation. loop with non-constant loop condition must terminate within 250 iterations Then, i change the limit of looping constant: set_global_assignment -na...Show More
Altera_ForumHonored Contributor16 years agowhy do you have such a large loop? such things often dont represent real hardware.
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
