10 years agoOptimal ALU
Dear all, I'm creating an ALU for a homemade NIOS II compatible processor with Quartus Prime, targeting the Cyclone V. I discovered that, depending on the operations ordering, the ALU has a differ...
10 years agoThe following SystemVerilog code has been compiled with Quartus Prime 16.0.0, targeting Cyclone V 5CGXFC5C6F27C7. Inputs are synchronous.
module Alu(input logic operand1, operand2, input logic control, input logic clock, output logic result);
always_ff @(posedge clock) begin
case (control)
'h0: result <= operand1 + operand2;
'h1: result <= operand1 - operand2;
'h2: result <= operand1 & operand2;
'h3: result <= operand1 | operand2;
endcase
end
endmodule For this ALU, there is a difference of a few MHz for an average frequency of 800MHz between the fastest and the slowest design. However, for a bigger ALU implementing all NIOS II's arithmetic (except multiply and divide) and logical operations, the fastest design I found is clocked at 200MHz while the slowest runs at 150MHz… That's huge, and just by changing operations order!
