openvino : what is the reason for this , how to resolve?
after running this script , the following errors are obtained
script: ./demo_squeezenet_download_convert_run.sh
ERRORS:
################|| Downloading models ||################
========== Retrieving /root/openvino_models/models/public/squeezenet1.1/squeezenet1.1.prototxt from the cache
========== Downloading /root/openvino_models/models/public/squeezenet1.1/squeezenet1.1.caffemodel
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 852, in _validate_conn
conn.connect()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 326, in connect
ssl_context=context)
File "/usr/lib/python3/dist-packages/urllib3/util/ssl_.py", line 332, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/lib/python3.6/ssl.py", line 407, in wrap_socket
_context=self, _session=session)
File "/usr/lib/python3.6/ssl.py", line 817, in __init__
self.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 1077, in do_handshake
self._sslobj.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 689, in do_handshake
ConnectionResetError: [Errno 104] Connection reset by peer
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.6/dist-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 367, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/lib/python3/dist-packages/six.py", line 692, in reraise
raise value.with_traceback(tb)
chunked=chunked)
conn.connect()
self.do_handshake()
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
File "/opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/downloader/downloader.py", line 65, in try_download
chunk_iterable = start_download()
File "/opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/downloader/downloader.py", line 244, in <lambda>
lambda: model_file.source.start_download(session, CHUNK_SIZE)):
File "/opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/downloader/common.py", line 172, in start_download
response = session.get(self.url, stream=True, timeout=DOWNLOAD_TIMEOUT)
File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 546, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
########## Error: Download failed
################|| Post-processing ||################
FAILED:
squeezenet1.1
Error on or near line 159; exiting with status 1
- Titanameda
The guide which is followed :
- JohnT_Altera
Its look like you are installing the wrong BSP. You will need to run "export AOCL_BOARD_PACKAGE_ROOT=/opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1" as this will be the BSP installed into your system as you are using this board.
If you "a10_1150_sg1" is install in the different directory then you can changed "export AOCL_BOARD_PACKAGE_ROOT=/opt/intelFPGA_pro/18.1/hld/board/a10_1150_sg1" which is the same directory of the a10_ref BSP.
- Titanameda
Hi
a10_1150 is installed , as per the commands that are installed , so while diagnosis it is searching for a10_ref so file , where to edit the environmental variables
echo $AOCL_BOARD_PACKAGE_ROOT/
/opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1/
root@tata:~# aocl install
Do you want to install /opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1? [y/n] y
aocl install: Adding the board package /opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1 to the list of installed pckages
aocl install: Setting up FCD
aocl install: Running install from /opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1/linux64/libexec
Looking for kernel source files in /lib/modules/4.15.0-70-generic/build
Using kernel source files from /lib/modules/4.15.0-70-generic/build
Building driver for BSP with name a10_1150_sg1
make: Entering directory '/usr/src/linux-headers-4.15.0-70-generic'
CC [M] /tmp/opencl_driver_zVe9aV/aclpci_queue.o
CC [M] /tmp/opencl_driver_zVe9aV/aclpci.o
CC [M] /tmp/opencl_driver_zVe9aV/aclpci_fileio.o
CC [M] /tmp/opencl_driver_zVe9aV/aclpci_dma.o
CC [M] /tmp/opencl_driver_zVe9aV/aclpci_pr.o
CC [M] /tmp/opencl_driver_zVe9aV/aclpci_cmd.o
LD [M] /tmp/opencl_driver_zVe9aV/aclpci_a10_1150_sg1_drv.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/opencl_driver_zVe9aV/aclpci_a10_1150_sg1_drv.mod.o
LD [M] /tmp/opencl_driver_zVe9aV/aclpci_a10_1150_sg1_drv.ko
make: Leaving directory '/usr/src/linux-headers-4.15.0-70-generic'
root@tata:~# aocl diagnose
/opt/intelFPGA_pro/18.1/hld/board/a10_ref/linux64/libexec/diagnose: error while loading shared libraries: libaltera_a10_ref_mmd.so: cannot open shared object file: No such file or directory
Warning:
No devices attached for package:
Warning:
Vendor: Intel(R) Corporation
Found no active device installed on the host machine.
Please make sure to:
1. Set the environment variable AOCL_BOARD_PACKAGE_ROOT to the correct board package.
2. Install the driver from the selected board package.
3. Properly install the device in the host machine.
4. Configure the device with a supported OpenCL design.
5. Reboot the machine if the PCI Express link failed.
DIAGNOSTIC_FAILED
Warning:
/home/tata/Sharath/hddlf_1150_sg1
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
CURRENT VARIABLES IN BASHRC
####intel openvino###
export INTELFPGAOCLSDKROOT="/opt/intelFPGA_pro/18.1/hld"
export QSYS_ROOTDIR="/home/tata/intelFPGA_pro/18.1/qsys/bin"
export PATH=/home/tata/intelFPGA_pro/18.1/quartus/bin:$PATH
source /opt/intel/openvino/bin/setupvars.sh
export PATH=/opt/intelFPGA_pro/18.1/quartus/bin:$PATH
#opencl via openvino
export PATH=/opt/intelFPGA_pro/18.1/hld/bin:$PATH
source $INTELFPGAOCLSDKROOT/init_opencl.sh
- JohnT_Altera
Could you performed "AOCL UNINSTALL" in order to uninstall the BSP that is not used? Are you able to detect the board when you use "lspci" command?
