Titanameda
6 years agoopenvino : what is the reason for this , how to resolve?
after running this script , the following errors are obtained script: ./demo_squeezenet_download_convert_run.sh ERRORS: ################|| Downloading models ||################ ========== Retriev...
JohnT_Altera
6 years agoHi,
Its look like you are installing the wrong BSP. You will need to run "export AOCL_BOARD_PACKAGE_ROOT=/opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1" as this will be the BSP installed into your system as you are using this board.
If you "a10_1150_sg1" is install in the different directory then you can changed "export AOCL_BOARD_PACKAGE_ROOT=/opt/intelFPGA_pro/18.1/hld/board/a10_1150_sg1" which is the same directory of the a10_ref BSP.
