OpenCL error on code compilation
Dear all,
I would like to use OpenCL SDK for a Terasic DE5-Net to deploy my algorithm (I am using Quartus 18.1 and OpenCL SDK 18.1). I successfully run the examples provided by Intel FPGA for OpenCL and they work. Thus, I am trying to compile my code, which is an integer iFFT based on the Cooley-Tukey algorithm. The OpenCL emulator gives me correct results when I run the code on the x86 machine. But, when I try to generate the .aocx for the DE5-Net, the compiler returns with the following warnings and one error (after 5/6 hours of compilation):
..several warnings about auto unrolled loop..
Compiler Warning: removing out-of-bounds accesses to xtmp1.i.i.i
Compiler Warning: removing out-of-bounds accesses to xtmp2.i.i.i
Compiler Warning: removing out-of-bounds accesses to xtmp3.i.i.i
intelFPGA/18.1/hld/board/terasic/de5net/tests/fft1Dint/device/fft1dint.cl:1424: Compiler Warning: Aggressive compiler optimization: removing unnecessary storage to local memory
Error: exception "std::bad_alloc" in PostBuildSteps [ifft_512_function ifft_512_function ]Error: Verilog generator FAILED.
Could you please provide me more information about this error? How can I understand which error in my code is linked to this output (buffer allocation or something else)?
Thank you for your support.
Federico
