9 years agoOpencl complie Error: Evaluation of Tcl script import_compile.tcl unsuccessful
when I complie my kernel, export "Error: Compiler Error, not able to generate hardware". When I chaeck the file "quartus_sh_complie.log", it only says"Error (23031): Evaluation of Tcl script import_compile.tcl unsuccessful", how do I know what causees the error and how to change my kernel? Thanks!22 Replies
Hi HRZ,
I have the same problem. But this only happens to my designs with large size (70% utilization). It will say 'failed to generate hardware' after around 10 hour's compilation. Here is my quartus_sh_compile.log. And by the way, the <installation directory>/quartus/bin was not in my path when that happend, but the hardware could be generated for my other kernels with small size. aoc --version Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler Version 16.1.0 Build 196 Copyright (C) 2016 Intel Corporation quartus_map --version Quartus Prime Analysis & Synthesis Version 16.1.0 Build 196 10/24/2016 SJ Pro Edition Copyright (C) 2016 Intel Corporation. All rights reserved. - Altera_Forum
--- Quote Start --- Thank you for the quick reply. The board I'm using is Gidel Proc10A X115 which has an Arria 10 FPGA on. --- Quote End --- good afternoon, colleague I also use the gidel board (proceV). Do You know where to download the procewizard? Very need pin information
