16 years ago --- Quote Start --- But this schematic inside EPM3064A in same hardware don't working :-(. --- Quote End --- You're talking in riddles. I assume, that the schematic as such is working, but possibly the part isn't behaving as expected with the external circuitry. Real 74LS245 hasn't open drain outputs, so it can't behave identically. Actually, I don't understand why you are using open drain at all? For the same reason, I can't recommend a pull-up value.
