16 years ago --- Quote Start --- The open-drain configuration is required to allow the pin to sink current. --- Quote End --- Sorry, I don't get why you would need a specific dedicated IOE configuration for that purpose. If the data output at the IOE is permanently tied to ground, and the original data signal is negated and then used as Output Enable, then you effectively has an open drain output.
