12 years agoOne shot pulse
Hi all,
I am beginner in VHDL. I am doing tutorial for one shot pulse. But, I am little bit confuse. What does 'idle' meaning in this code? and how do I can modify this VHDL code to generate pulse signal? I try to change the VHDL code by modifying the pulse <= '1'; to 0,1,0 in order to make it pulse signal. When I programmed into FPGA board, the light always on. Why does it happens? ---------------------------------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity pulse_5clk is port (clk,reset: in std_logic;--reset=SW17 go,stop: in std_logic;--go = SW0, stop =SW1 pulse: out std_logic);--pulse=LEDR0 end pulse_5clk; architecture fsm_arch of pulse_5clk is type fsm_state_type is (idle,delay1,delay2,delay3,delay4,delay5); signal state_reg, state_next: fsm_state_type; begin --state register process (clk,reset) begin if (reset='1') then state_reg <=idle; elsif (clk'event and clk='1') then state_reg <=state_next; end if; end process; --next-state logic & output logic process (state_reg,go,stop) begin pulse <='0'; case state_reg is when idle => if go = '1' then state_next <=delay1; else state_next <=idle; end if; when delay1 => if stop = '1' then state_next <=idle; else state_next <=delay2; end if; pulse <= '1'; when delay2 => if stop = '1' then state_next <=idle; else state_next <=delay3; end if; pulse <= '1'; when delay3 => if stop = '1' then state_next <=idle; else state_next <=delay4; end if; pulse <= '1'; when delay4 => if stop = '1' then state_next <=idle; else state_next <=delay5; end if; pulse <= '1'; when delay5 => state_next <=idle; pulse <= '1'; end case; end process; end fsm_arch;
