It might be easier if you try and explain what you are trying to do.
VHDL has no special number system. I think you're getting confused over the typing system.
An integer in VHDL is just a number. If used in synthesisable code, the synthesisor should convert it into a 32 bit 2's compliment notation.
The numeric_std library defines the unsigned and signed types. unsigned is pure 2^n logic, signed is 2s complement. But the reason we use unsigned is as followed:
1. It gives access to the bits inside the VHDL code.
2. We can set the length ourselves.
(these two also hold true for std_logic_vector also)
3. We can do arithmatic with it.
4. It will roll over - integer type will not (this is useful for things like address generation for FIFOs).
So, I think you're trying to run before you can walk. re-writing the basics that already exist in VHDL show you're trying too much too soon and overcomplicating your learning.
